hey everybody, first post here so lets see how it goes! i'm new to PC building and would love some tips or ideas about what i wanna do. for the full set up(being the monitor, peripherals, and the desktop itself i have a budget of around $2,500. i'm building this system so that it doesn't need to be upgraded in the near future(being anything before 3 years) i'm going to be building in the meshify c with a ryzen 7 2700x, at least 16 gigs of ram, but im not sure what to do for a gpu. i don't want to do anything lower then a 1080 but would a 1080ti be worth putting in? also with those specs what would you guys recommend i play on for resolution(as im building this pc to be a gaming pc), i was thinking 1920x1080 would be fine, but would 2560x1440 be worth it?
https://linustechtips.com/topic/956545-first-build/
At this point, i'd rather u save the money and wait until end of the month and get the 11-series Nvidia cards or save a bit more on the 1080ti when the new card is out.
And why not go for i7? They're the bomb compared to AMD's.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/956545-first-build/#findComment-11613549
PCPartPicker part list: https://pcpartpicker.com/list/MxmsnH
Price breakdown by merchant: https://pcpartpicker.com/list/MxmsnH/by_merchant/
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor  ($319.79 @ SuperBiiz) - good choice
CPU Cooler: ARCTIC - Freezer 33 eSports ONE (Black/White) CPU Cooler  ($32.28 @ Newegg) - //@seoz//
Motherboard: Asus - Prime X470-Pro ATX AM4 Motherboard  ($155.00 @ B&H) - ASUS Prime series are the best value motherboards on the market
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Amazon) - Going for a Black/White theme here soooo
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  ($99.89 @ OutletPC) - SSD value king
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC) - HDD value king
Video Card: EVGA - GeForce GTX 1080 Ti 11GB iCX GAMING Video Card  ($704.98 @ Newegg) - 1080 Ti that's white-ish
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  ($88.99 @ SuperBiiz) - best case
Power Supply: EVGA - 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ B&H) - T2 and cheap
Case Fan: ARCTIC - BioniX F140 (Black/White) 104.0 CFM  140mm Fan  ($12.78 @ OutletPC) - //@seoz//
Case Fan: ARCTIC - BioniX F120 (Black/White) 69.0 CFM  120mm Fan  ($12.55 @ OutletPC) - //@seoz//
Monitor: Dell - S2716DGR 27.0" 2560x1440 144Hz Monitor  ($449.95 @ Amazon) - Cheapest 27" 1440p 144HZ Gsync monitor
Keyboard: Cooler Master - MasterKeys Pro L Wired Standard Keyboard  ($133.30 @ Newegg) - RGB, Mechanical
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($49.99 @ Amazon) - best mouse
Headphones: SteelSeries - Arctis 5 7.1 Channel  Headset  ($92.00 @ Amazon) - Best $100 gaming headset
Generated by PCPartPicker 2018-08-05 23:56 EDT-0400
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/956545-first-build/#findComment-11613562
26 minutes ago, ngagnon13 said:
You either want 1440p 144hz IPS with a new monitor, or 4k 60hz IPS
Wouldn't go past a 1070ti/1080 for the best value.
Are you doing anything that requires 8 or more cores? Because you could easily get Threadripper 2 for that budget coming shortly.
Better off with an IPS free-sync version instead for daily use.
If you're buying extra fans Noctua is the way to go.
https://linustechtips.com/topic/956545-first-build/#findComment-11613606
The cheapest decent 1440p 144HZ IPS (Pixio PX277N) is $500
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/956545-first-build/#findComment-11613614
The Nixeus display uses the same panel at like $430
https://pcpartpicker.com/product/xYx9TW/nixeus-nx-edg27-270-2560x1440-144hz-monitor-edg-27
https://linustechtips.com/topic/956545-first-build/#findComment-11613620
oh god those bezels
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/956545-first-build/#findComment-11613623
is the 11 series dropping at the end of the month? i wasnt aware i hadnt heard much about the 11 series, also just saving a couple of bucks by going ryzen
https://linustechtips.com/topic/956545-first-build/#findComment-11615102
also the list ive put together goes as follows, a little over but im willing to pay the bit of extra
PCPartPicker part list: https://pcpartpicker.com/list/3XDLw6
Price breakdown by merchant: https://pcpartpicker.com/list/3XDLw6/by_merchant/
Motherboard: Gigabyte - X470 AORUS GAMING 5 WIFI ATX AM4 Motherboard  ($171.58 @ Amazon)
Memory: Corsair - Vengeance RGB Pro 16GB (2 x 8GB) DDR4-3000 Memory  ($186.98 @ Newegg)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  ($126.55 @ Newegg Marketplace)
Storage: Seagate - BarraCuda Pro 4TB 3.5" 7200RPM Internal Hard Drive  ($168.98 @ Amazon)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB FTW3 GAMING iCX Video Card  ($734.98 @ Newegg)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case  ($101.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.89 @ OutletPC)
Case Fan: Fractal Design - X2 GP-12 (Black) 52.3 CFM  120mm Fan  ($11.99 @ SuperBiiz)
Case Fan: Fractal Design - X2 GP-14 (Black) 68.4 CFM  140mm Fan  ($13.89 @ OutletPC)
Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor  ($458.99 @ Amazon)
Keyboard: Razer - Huntsman Elite Wired Gaming Keyboard  ($185.15 @ Walmart)
Mouse: Razer - Mamba Tournament Edition Wired Laser Mouse  ($79.00 @ Amazon)
Other: PECHAM Extended Non-Slip Waterproof Rubber Base 3mm Thick Gaming Mouse Pad, XX-Large - Black  ($18.99 @ Amazon)
Total: $2674.62
Generated by PCPartPicker 2018-08-06 10:06 EDT-0400
https://linustechtips.com/topic/956545-first-build/#findComment-11615313
I think compared to Ryzen, single core & quad core performance is better on the i7 8700k because not many softwares can fully utilize Ryzen's 8 cores. And it's just a difference of 30 dollar.
https://linustechtips.com/topic/956545-first-build/#findComment-11615337
if you're just gaming, an i7 8700k will be the better option.
https://linustechtips.com/topic/956545-first-build/#findComment-11615721
while it will be primarily a gaming pc, id like to dabble in things like unity and video editing, the heavy application of the pc will be gaming but it will do a few other things as well
https://linustechtips.com/topic/956545-first-build/#findComment-11616224
not wrong but personally i dont see much of a performance difference be tween the two except for maybe a few frames, both are exceptional cpus in their own applications
https://linustechtips.com/topic/956545-first-build/#findComment-11616232
