Front panel distorted only when using realtek drivers
Build link : https://pcpartpicker.com/list/q7t2bX
Today I was troubleshooting an issue with my front panel on my new build. The case is an FD Define R6. The USB wasnt working. I reseated all the connectors and it fixed the issue. Later, I plugged my headphones back into the front panel and they were very low, could barely hear anything even at full volume. I didn't install the motherboard audio drivers up until this point. I've had this build for about a week. I decided to install the motherboard drivers from the ASRock website.
Here's the issue:
When realtek drivers from the website are installed, my headphones experience extreme audio distortion. It's very similar to if a cable on headphones would be going bad. The distortion happens only if I have a device plugged in the back and headphones in the front.
Here's what I've done so far:
-    checked the motherboard  front panel HD audio connection. Reseated the header.
-    Unplugged all other front panel headers for USB in case it was causing noise.
-    Rerouted the HD audio cable in case it was touching anything and causing noise.
-    Used different headphones, and a different speaker on the back. Checked that my current headphones work on other devices.
-    Reinstalled windows entirely.
-    Plugged PC directly into wall instead of surge protector in case grounding was an issue (I have a server grade surge protector anyway, so that shouldnt be a problem...)
-    I am not OCed. I read that could cause issues like mine, but it doesnt seem to appy to me.
**I'm not sure what happened. Could my mobo be going bad? **
P.S. - a friend got the same exact build, minus GPU, and his front audio panel works fine with realtek drivers.
