Sooooooo im building a new pc and those are my parts :D :
Please tell me if its unstable or something with the lengh and everything
++++( i dont plan on OC)
CPU : i5 8400
CPU cooler : Noctua - NH-D14
Motherboard : ASUS - PRIME-B360-PLUS
RAM : HyperX - HX424C15FB2K2-16 (2x8)
GPU : EVGA GeForce GTX 1060 GAMING, 06G-P4-6161-KR, 6GB GDDR5, ACX 2.0 (Single Fan)
SSD : Adata 120 GB (ill use it to windows and programs like steam)
HDD: Seagate Barracuda 1TB
Case: NZXT S340 white/black
PSU : Corsair - CP-9020090-EU - 550W ( its 80+ gold rated and Modular)
Please tell me if there is bottlenecking , unstableness in some kind Thank you :D
https://linustechtips.com/topic/956203-help-about-my-pc-plan/
CPU : i5 8400
Things are looking okay. Just a few notes.
1.) You can get by without the aftermarket cooler, unless you really want it for its looks. You don't have to worry about the acoustics of the stock cooler as well. It will be drowned out by the NZXT case.
2.) You can swap out your case to an NZXT H500. It's newer, better, and the same price as the S340.
If you live in a country that https://pcpartpicker.com supports, then you can input your build there to see the lowest prices for each part. You might also be swap out some more parts if you see something better.
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11610892
If you are not living near the ecuator, I would suggest you to just save your money and just use the stock cooler. But if you want aesthethics, why the heck not :P
For the case go for NZXT H700 or H500. The airflow and the cable management is way better.
Other than that everything seems good there but i would suggest for you to hold on to your money first as by the end of August they will be launching the Geforce 11-Series and also in October the 9th gen intel.
So you can either get the same specs cheaper or get something newer :D
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11610896
I kinda cant hold myself xD i mean this is for a friend im just trying to be sure this PC will be fine , Im getting a different system with 1070ti so im pretty set
But heck ill get the h500 like you said its the second time someone suggests that to me as you see in the second comment :D
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11610938
Don't make a mistake like me. For the past 2 weeks i've been changing between 3 casing and 2 cpu cooler.
Finally i got satisfied with the H115i Pro RGB & NZXT H700
2 weeks ago
Last week
This week
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611017
1 minute ago, Randomguy123 said:
So this are my specs tell me please if its unstable or not asteticly good , and about the H500 NZXT case does it have a good air flow ?
CPU : i5 8400
CPU cooler : NH-D14
DONT USE THAT COOLER!
Its such a waste of money for a non-k chip. Its okay to use the stock cooler with i5-8400
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611024
Check the system again Please i uploaded something stupidly :D
And i plan on staying with this system for like 3 years :D
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611029
Still man. That cooler is just stupid for non overclockable cpu. Stay with the stock cooler. Also i suggest a gtx 1070.
Thats not for me , the guy plans on playing Fortnite, Maybe BF , he is just new to PC gaming , he used to ONLY play Fortnite on PS
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611044
why ? is the NH D14 isnt good ?
i finaLLY chose aio for aesthetics. and the ma620p i used before covers the top of my ram, so cant see its rgb
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611045
RGB isnt important to the guy im building it for
and check this out its my second post , i changed the Motherboard to an ATX :
https://linustechtips.com/main/topic/956223-need-help-in-pc-build-d
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611053
7 minutes ago, LukzForEver said:
Its still ok with the gpu. But the cooler for 90dollar doesnt make sence. No diffrence in performace
than the free stock one.
isnt the NH D14 won an award for best cooler or something ? i mean i watched reviews on it and its pretty deecent, and any recomendations for good CPU AIR cooler ?
12 minutes ago, Konrad_K said:
I'd definitely get a different cooler. A hyper 212 is cheaper and your CPU is locked anyway. The money you would save on that cooler could get you a larger SSD. (Imho a 240-250GB is the minimum- a 860 EVO should work fine)
Yo ima post for my own build i planned so stay tuned here in chat and ill send a link to the post Please :D
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611061
Dude. You are not getting high temps with i5-8400, also the cpu will come with a free cpu cooler. You need a cpu like i5-8600k to buy aftermarket cooler and if you will OVERCLOCK.
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611082
5 minutes ago, dro3m said:
The D14 is WAY to overkill for your CPU. Something like the hyper 212 evo is more the enough. I only recommend it if your going with a overclockable chip, but you don't have one.
Advise me on an other Cooler please air cooler and deecent 1 Plesae :D
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611094
4 minutes ago, airdeano said:
please be considerate to the community, do not make many threads on the same topic throughout the forums.
confuses you and the community on what your real achievement is. all threads merged to this one thread.
Yeah i didnt mean i posted and when i tried to get into it trough link it said it didnt excist so i posted it again. yeah sorry
2 minutes ago, LukzForEver said:
If the ram is ddr4 then its ok
Yeah its DDR4 :D
Nothing to say about the CPU cooler ?
isnt it way OVERKILL
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611109
11 minutes ago, LukzForEver said:
You dont need an aftermarket cooler... For that cpu. Is it hard to understand?
Thats like getting a cooler more expensive than the cpu.
Can you advise me on a good CPU cooler that looks good ?
cuzz someone advised me hyper 212 evo but i didnt like how it looks
https://linustechtips.com/topic/956203-help-about-my-pc-plan/#findComment-11611120
