help plzzzz
Go to solution Solved by ForeseenVisionz,
in bios goto boot priorites and make in #1
Idk what to do can't get past this point
I'm installing new window 7 software to completely new system and my disk 0 is unallocated and the error says windows is unable to install to the selected location. Error:0x80300024
this is a brand new hard dive on a brand new system
Seagate 1tb harddrive
https://linustechtips.com/topic/95611-help-plzzzz/
In the grim darkness of the far future, there is only a GTX 1080, just a single 1080, where my glorious PC once stood....
For that is all I need, For the Emperor of Man, Jen-Hsun Huang, protects. We march for Nvidia, and we shall know no fear!
https://linustechtips.com/topic/95611-help-plzzzz/#findComment-1280049
You might have to reformat the drive.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/95611-help-plzzzz/#findComment-1280071
yes but I only have 1 harddrive
read the description and are u sure u booting too that one? other than reformatting i dunno
https://linustechtips.com/topic/95611-help-plzzzz/#findComment-1280078
how do I know if I'm booting from it and how do I reformat
are theryre any other hdd or ssd connected? what are u installing windows off? is it booting from what your installing windows off of like it should be. goto boot priorites and check.
https://linustechtips.com/topic/95611-help-plzzzz/#findComment-1280255
no other memory is pluged in
installing off of cd
and it is booting off of it
https://linustechtips.com/topic/95611-help-plzzzz/#findComment-1280294
unplug it and plug it in. start all over again and make sure its booting off of the cd.
https://linustechtips.com/topic/95611-help-plzzzz/#findComment-1280328
https://linustechtips.com/topic/95611-help-plzzzz/#findComment-1280390
