15 minutes ago, Helmer said:
What's it for?
8Gb ram is a bit on the short end, for most uses I'd recommend 16Gb .
Again, depending on what it's for; consider *heavily* on buying an SSD! Makes a world of difference!
Basic everyday use for know adding more ram and a m.2 as I go
