Hi there DatWolf :)
Is being some time since I don't check prizes but could you answer some questions first in order to give you some piece of advice?
What are you going to do with the rig:
1. Name games you actually want to play and future things you want to play (would be a shame you buy something and in 6 months you cannot play that sweet new release).
2. Name also programs and other things you might do. I don't think anything proffesinoal related since you are making this question but if you tend to multi task or use heavy cpu programs could be good to know when choosing one.
https://linustechtips.com/topic/955626-help-build-a-pc/#findComment-11606439
