Scrape it with a knife blade maybe?
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/955483-cleaning-gpu-problem/#findComment-11604830
Try using a sponge and just scrubbing hard.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/955483-cleaning-gpu-problem/#findComment-11604831
That would scratch the heatsink. Yes, thermal paste would fill in the gaps, but still.
SPECS:
https://linustechtips.com/topic/955483-cleaning-gpu-problem/#findComment-11604833
Maybe, but if you're half careful with a nice xacto blade or something, you should be able to get a good amount off without damage.
https://linustechtips.com/topic/955483-cleaning-gpu-problem/#findComment-11604848
2 minutes ago, The321 said:
@kelvinhall05 the soft or hard side ?
Try both.
SPECS:
https://linustechtips.com/topic/955483-cleaning-gpu-problem/#findComment-11604856
7 minutes ago, AngryBeaver said:
Just use alcohol and an old credit card or something. If it is being stubborn just make sure to do it more vigorously. The heat from the friction should start to make it come off.
Never thought of that! Credit card would definitely be a good, non harming scraper!
https://linustechtips.com/topic/955483-cleaning-gpu-problem/#findComment-11604914
12 minutes ago, The321 said:
@kelvinhall05 but the rough side will scratch it right ?
No, because it's some kind of fabric or something rubbing some metal. So no, it shouldn't scratch it (unless you use steel wool, which wouldn't work well).
SPECS:
https://linustechtips.com/topic/955483-cleaning-gpu-problem/#findComment-11604967
