9 hours ago, Locutus494 said:
Are the drivers for the network adapter installed? (check in device manager) Is the network adapter enabled in the BIOS/UEFI? Have you tried a different cable?
The cable works just fine on a laptop i I tried it with, and the network adapter is enabled in the BIOS. But i dont know if i have the drivers, would thay be on the DVD that came with the board?
Yes, your board should have come with all the drivers it needs. You're better off though just going to the manufacturer's website and downloading the latest driver (assuming you have another computer you can use to download it). The one on the provided CD could be very out of date.
