3 minutes ago, BloodyGlitch said:
I have a prebuilt PC and I will try to put an SSD in it. The problem is, my power supply doesn't have another Sata cable to power the SSD, so is there an alternative way to power an SSD? Preferably under $10
Get a new PSU. There are janky ways of doing this, but none will be recommended for long term use. There are ways to power SATA drives off USB and external power supplies, but they would be for troubleshooting purposes, not continuous use
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/955210-alternative-sata-power/#findComment-11602459
Does it have a spare 4-pin Molex on the PSU? If so, you can pick up Molex to SATA power adapters.
https://www.amazon.ca/StarTech-com-PYO2LP4SATA-Power-Cable-Adapter/dp/B0002GRUV4/ref=sr_1_1?ie=UTF8&qid=1533241800&sr=8-1&keywords=molex+to+sata&dpID=5110WUd090L&preST=_SY300_QL70_&dpSrc=srch
https://linustechtips.com/topic/955210-alternative-sata-power/#findComment-11602665
