Hello!
I discovered today that my rear sound panel(motherboard) and my front sound panel (case) have been switched.Now my computer detects the motherboard panel as front and my case as rear.Any idea how to resolve it.I tried tweaking the drivers,uefi but nothing seems to work.
https://linustechtips.com/topic/955078-audio-panels-switched/
That's odd but I would suspect its a driver problem.  Are you using ones from the motherboard manufacturers site?
https://linustechtips.com/topic/955078-audio-panels-switched/#findComment-11601130
Have you completely removed the drivers between tries?
https://linustechtips.com/topic/955078-audio-panels-switched/#findComment-11601164
