Front io Headers
Go to solution Solved by Altruist,
Never mind i confronted my manual and i'd done everything correctly thanks everyone for contributing.
3 minutes ago, Altruist said:
My motherborad seems to have more headers ;-;
Yeah it depends on the motherboard, look in the motherboard manual on what each of the pins does, and connect the right pins into right places.
Also the Front IO pin place seems very similar to front audio port, so make sure you are connecting the wires into the right place, and for that consult the manual.
https://linustechtips.com/topic/954712-front-io-headers/#findComment-11597748
