Is this a decent PC build
1 member has voted
  1. 1. Is this a decent PC build
    • Yes
      1
    • No
    • Needs Improvement (please specify)
  2. 2. What parts need to be changed?
    • CPU
    • Motherboard
    • RAM
    • SSD
    • Graphics Card
      1
    • Case
    • Power supply
This is my first ever PC build and I plan on using it for school work light 3D modeling and occasional gaming (Fortnite and Kerbal Space Program). I have a 650$ish budget on the PC without windows or peripherals. My budget a little bit flexible but I don't want to break 700$. I don't care if I have to play games on low settings I just want a PC that will last and be easily up-gradable for future hobbies. If there are any issues with compatibility or bottle necking PLEASE TELL ME. If you have any suggestions on different parts please tell me. And if you say this build will suck and I am an idiot it will not offend me. This is like my 3rd iteration so if it looks like I am spamming the same post today I am not. Also PLEASE SUGGEST better cheap cases with side windows.
here are the parts I am looking at.
PCPartPicker part list: https://pcpartpicker.com/list/HdxxbX
Price breakdown by merchant: https://pcpartpicker.com/list/HdxxbX/by_merchant/
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($89.99 @ Amazon)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($91.98 @ Newegg)
Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory  ($80.98 @ Newegg)
Storage: Western Digital - Blue 250GB M.2-2280 Solid State Drive  ($64.99 @ Amazon)
Video Card: XFX - Radeon RX 580 8GB GTS XXX ED Video Card  ($249.99 @ Amazon)
Case: Cougar - MX330-X ATX Mid Tower Case  ($31.99 @ SuperBiiz)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($45.59 @ SuperBiiz)
Total: $655.51
Generated by PCPartPicker 2018-07-31 18:41 EDT-0400
https://linustechtips.com/topic/954545-need-help-with-first-pc-build/
UPDATE
I changed out some parts and upgraded the cpu while downgrading other components like the ssd and motherboard
PCPartPicker part list / Price breakdown by merchant
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($149.99 @ Amazon)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($49.99 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($80.98 @ Newegg)
Storage: ADATA - XPG SX6000 256GB M.2-2280 Solid State Drive  ($62.89 @ OutletPC)
Case: SAMA - Maxcool-BK-15LEDLight MicroATX Mid Tower Case  ($48.27 @ Newegg)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $682.10
Generated by PCPartPicker 2018-07-31 18:46 EDT-0400
Not sure what styling you are looking for. Suggest going through the link below, and checking manufacturer's site for the candidates you like most to see what features they give you. Personally I'd prioritize toolless drive bays that are adjustable and case fan quantity as important metrics along with mesh for airflow and removable air filters in addition to a side panel.
https://pcpartpicker.com/products/case/#sort=price&s=1
Edited by Sernefarian
LINK NEEDED! lmao
Rawr.
5 minutes ago, Nstud said:
UPDATE
so, you just took the list i sent you and placed it here?
Just now, Nstud said:
@Herman Mcpootis yes did I not say that you made It?
not really, no. I'm fine with showing the list, just find how you worded it abit wierdly.
11 minutes ago, Nstud said:
UPDATE
Total: $682.10
@Herman Mcpootis made this build I forgot to say that if you did not see that yet
1 hour ago, Nstud said:
UPDATE
Total: $682.10
Great build actually. And you seem to be comfortable with Mail-In rebates. For that matter, how about we tweak some things a bit?
Case: Thermaltake - Core G21 Tempered Glass Edition ATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($39.99 @ Newegg)
Case Fan: Thermaltake - CL-F011-PL12BL-A 41.0 CFM  120mm Fan  ($4.49 @ SuperBiiz)
Total: $672.80
Generated by PCPartPicker 2018-07-31 20:30 EDT-0400
8 minutes ago, forregacc02 said:
the M12 is worse than the CX550M, it's old as dirt and missing several protections.
2 minutes ago, Nstud said:
@forregacc02 thank you for that I will be implementing that into my build.
You're welcome :)
3 minutes ago, Nstud said:
do you have any suggestions on how to get a cheaper graphics card to bring it down closer to 600$. I don't mind playing games on lower settings
Not really. The graphics card choice in your build is particularly great value. If I were to build a PC now, I would choose the same graphics card.
Okay... I'm not saying you're wrong, but could you enlighten me on this? I believe the EVO is like the refresh of the original M12 which has added features for modern hardware. Could you send some links showing that the M12 Evo is as you stated.
 IIRC they didn't add the protections in.
Well.. I did my research. The EVO edition, the 520w and 620w are basically the same as the old ones except that they are updated for Haswell. JonnyGuru personally said:
5b610a07a5e42_ScreenShot2018-08-01at9_16.25AM1.png.5394730cd8fd65f8c13dc812f9d23a5c.png
However, it's still a group-regulated PSU with no DC-DC unless you get the 750w and 850w.
I would have to agree with you here then. Your original choice of PSU is better.
