cpu upgrade help
Go to solution Solved by jiyeon,
Just now, lifeguard175 said:
can i change motherboards and go to an amd?
Yeah, you can go to AMD such as B350 or X370, then you'd need a Ryzen 3/5/7.
It's not possible to run a 7400 with a B360, so I assume you don't have the PC yet?
i5-8400 or 8600K will be good choices.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/954464-cpu-upgrade-help/#findComment-11595420
https://linustechtips.com/topic/954464-cpu-upgrade-help/#findComment-11595466
