21 minutes ago, IrishDunner said:
I want to get a 3d printer, I have a budget of 400-500 ish euro, what's the best bang for buck I can get
I'm not too sure on if they ship to Europe, but you should check out some of Monoprice's 3D printers.
This one's equivalent to around 350 Eur https://www.monoprice.com/product?p_id=15711
I'm probably gonna get this one from them in not too long: https://www.monoprice.com/product?p_id=15365
https://linustechtips.com/topic/954372-3d-printer-help/#findComment-11594673
What makes it worth while is the plate heated
https://linustechtips.com/topic/954372-3d-printer-help/#findComment-11594682
For the first one on there, you get a 20x20x18cm build area, easy setup, heated build plate, USB and SD card connectivity, resolution of 100 microns (0.1mm), 150mm/sec printing speed, max extruder temp of 500F (260C), and the ability to print with ABS, PLA, XT Copolyester, PET, TPU, TPC, FPE< PVA, HIPS, Jelly, Foam, and Felty.
I'm not sure what competition is out there in that price range though.
https://linustechtips.com/topic/954372-3d-printer-help/#findComment-11594696
I recommend not going with the CR-10s if it's your first 3D printer. The Monoprice is so much less hassle and it's great for beginners. The 20x20 bed is sufficient for start and is so much easier to level.
I regret not getting a smaller 3D printer from the start. Now my CR-10 collects dust because i spent too much time trying to get it to work properly and I gave up. My Monoprice Select Plus is on it's way and I can't wait to print something good out of the box without hours and hours of fiddling.
https://linustechtips.com/topic/954372-3d-printer-help/#findComment-11600616
