I'v just finished with my build all im looking for is the cable's in which connect everything. I want red/black themed but I was unsure how many cables the whole PC needs. I would like if someone could tell me what cables I will need to buy from cablemod and how many of each different kind I need. Once again this is for a completed build I need every cable. Thanks :)
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  (£312.95 @ Amazon UK)
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  (£99.98 @ Amazon UK)
Motherboard: Asus - ROG Strix Z370-H Gaming ATX LGA1151 Motherboard  (£183.07 @ Amazon UK)
Memory: Corsair - Vengeance RGB Pro 16GB (2 x 8GB) DDR4-3200 Memory  (£188.40 @ Amazon UK)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  (£54.89 @ Amazon UK)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£52.97 @ Amazon UK)
Video Card: MSI - GeForce GTX 1080 Ti 11GB GAMING X Video Card  (£609.92 @ Amazon UK)
Case: Corsair - Carbide 400C ATX Mid Tower Case  (£79.52 @ Amazon UK)
Power Supply: Corsair - RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£101.16 @ Amazon UK)
Total: £1682.86
Generated by PCPartPicker 2018-07-31 07:48 BST+0100
        Current PC
CPU: I5-7400
GPU: Gigabyte 1050Ti
RAM: Crucial DDR4 8GB 2133mhz
CASE: GameMax Falcon
MOBO: Prime B250M-A
                                       Peripherals
Mouse: Corsair Sabre
Keyboard: Corsair Strafe
Mic/headphone: Blue Yeti /w JVC HA-SR50X
Mouse Mat: Razer Goliathus
https://linustechtips.com/topic/954256-what-cables-do-i-need/
All the cables you will need should come with the Power Supply and the Motherboard. You shouldnt need any additional cables beyond what everything will come with.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/954256-what-cables-do-i-need/#findComment-11593831
Always good to have a displayport / hdmi cable. I sadly had quite a few cases where people only had the power cable or still an old dvi or vga cable. I feel like donating everyone a dp 1.4 cable
https://linustechtips.com/topic/954256-what-cables-do-i-need/#findComment-11593841
hes not buying a monitor so would assume hes using what he has in place already and already has the proper display cables necessary.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/954256-what-cables-do-i-need/#findComment-11593843
Just so you're aware, the 1080 Ti you've chosen doesn't actually cost £610. PCPP is a bit broken, you'll have to pay £720 for it.
The PSU is also way overkill, 550W is plenty for overclocking. The Whisper M or Straight Power 11 are also good options.
And the Z370H is the ultra low end Z370P, just disguised and priced like a high end motherboard.
If you want to get custom sleeved cables, you need the 24-pin ATX, 2x 8-pin PCIe cables (do not get a single 8+8 pin cable, get two single 8 pin cables), a SATA power cable and a CPU 8-pin cable.
https://linustechtips.com/topic/954256-what-cables-do-i-need/#findComment-11593846
@Skiiwee29 I men't cable mods so it goes with the colour theme. I was wondering like what the cable names were that connect everything like to motherboard gpu psu fans. so I can buy them from cablemods or something
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/954256-what-cables-do-i-need/#findComment-11593848
@seon123 Which Motherboard would you replace it with within the same price range (Im down for a cheaper/better if there is one)
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/954256-what-cables-do-i-need/#findComment-11593852
For those you need 24 pin, 8 pin EPS for the CPU, and the PCIe ones for your GPU, which likely will be either 8+6 or 8+8. Sleeved extensions are all you should need.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/954256-what-cables-do-i-need/#findComment-11593854
The Z370 Extreme4 is a nice board. Ignore the blue hue from the chipset heatsink, that's just some lighting. The board itself is black/gray.
For Asus boards, there's the Prime-A and Z370F.
https://linustechtips.com/topic/954256-what-cables-do-i-need/#findComment-11593861
@seon123 I'm looking for a red/black mobo to match the GPU. Also I will not be mass OC just if the performance gets shit after the years of use.
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/954256-what-cables-do-i-need/#findComment-11593867
