I'm having an incredibly strange issue with my graphics card and drivers.
Whenever I try and play a game like grand theft auto or any pretty demanding game for that matter, within a couple min of start up the game freezes and crashes.
If I reinstall my graphics card drivers WITHOUT rebooting this fixes the issue for me... Until I reboot.
The GPU isn't over heating, and here are my pc specs:
Ryzen 1800x
GTX 1070 (Asus Strix)
16 gigs of ddr4
https://linustechtips.com/topic/952522-strangest-issue/
50 minutes ago, msm202 said:
I've had the GPU for over a year now I'm not sure if it's faulty, but it definitely seems stable once I reinstall the drivers without rebooting, I can even overclock it and it's fine using stress tests.
If it's new then rma it but if you bought used and no warranty try reapplying thermal paste
Firestrike
i7-8700k @5.0GHz w/ 1.30v, Corsair h100iv2, Gigabye Aorus gaming 7, 16GB(8x2) 2666MHz ddr4, Dual RX470's OC'd to 1390mhz(atm) in corssfire - liguid cooled with corsair h60's, 3.25 TB in Samsung SSD's, anidees white crystal cube case
Retired:
i5-4440k @3.2GHz, gigabyte ga-z87x-ud5h z87, 24GB DDR3, 3x1TB Seagate Baracuda HDD.
https://linustechtips.com/topic/952522-strangest-issue/#findComment-11578237
1 hour ago, Tibon said:
Hmm,a strange problem indeed.
Even if it is a faulty gpu, explaining the symptoms for an rma and proofing it would be difficult.
Motherboard bios update? Ram checked?
I just updated the bios no luck.. atleast I can play my games fine if I reinstall my drivers
https://linustechtips.com/topic/952522-strangest-issue/#findComment-11578438
