Deciding on a cooler
Solved by jiyeon,
Just now, szym3k said:Was the installation process for Arctic 33 eSports One tricky?
Nope, it was super simple provided you install it with the motherboard outside the case. The way it mounts seems like it's not fully onto the CPU, but I can assure you the way it mounts is both simple and effective, compared to something like a Cooler Master Hyper 212.
Arctic have YouTube videos for installing the Arctic 33 eSports coolers, these take no more than four minutes to install.
