1 minute ago, JohnCarlHenry said:
Is there any difference between a dual channel and a single channel ram?(assuming they both have the same total GB, have the same speed and latency)
From what I have read at the same clock and latency the Single Rank RAM modules will slightly outperform the dual rank kits.
Rawr.
dual channel RAM get nearly double the transfer rate, assuming your assumption means the performance of each stick is identical.
rank is different from channel
Desktop benching:
DOH! ... my prior statement is still true though.
a 1x8 Gig stick(single channel) compared to 2x4 gig sticks(dual channel) will have the 2x4 gig sticks performing better than the 1x8 gig stick. Perhaps as much as the difference between a 3000MHz 1x8 gig stick and a 3200 Mhz 1x8 Gig stick, assuming equally tight timings for the single channel stick's clock speeds.
Edited by Sernefarian
clicked the wrong thing lmao.
Rawr.
This is a good read: https://us.answers.acer.com/app/answers/detail/a_id/1664/~/what-is-dual-channel-mem
In a nutshell, it allows two lanes for memory access compared to a single lane like Single Channel operation. Theoretically doubling memory performance.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
actually more than that. Single channel vs dual channel is like 2 drives in RAID 1 vs 2 drives in RAID 0, you theoretically get double the performance, but realistically dont because splitting things in half takes time.
Desktop benching:
You live you learn. Bench link @ 2133 MHZ with the same timings.
http://ram.userbenchmark.com/Compare/HyperX-Fury-DDR4-2133-C14-2x4GB-vs-HyperX-Fury-DDR4-2133-C14-1x8GB/3554vs3555
~74% more performance for that particular kit. Possibly controller efficiency at play?
Rawr.
