Hi. I have recently built a new pc with a MSI motherboard. And since then every time I restart my Ducky Shine Zero is not responding until I hit function f12. Which is the N key roll over. Anyone know why this is happening.
Its not a big deal though just a bit annoying. I have disabled wake on usb in bios though didn't help.
Thanks.
https://linustechtips.com/topic/950204-duck-shine-zero-problem/
8 minutes ago, Ahajha said:
All I can think of is, is your keyboard plugged into a USB 2 or 3 (or 3.1) slot? I had issues with my keyboard (a Corsair one) plugged into USB 3, and it was resolved with a USB 2 port. Something to try.
Thanks, I think that might have solved it from changing from a USB2 Port to a USB 3. Seems to be working now:)
https://linustechtips.com/topic/950204-duck-shine-zero-problem/#findComment-11556892
