I recently bought an ASUS FX503VM which comes with an i5-7300HQ, 1060 3GB,8GB Of RAM and a 256gb SSD. I want to add a hardrive for more storage but I am unable to find the maximum hard drive size. Is anyone able to help? I've looked for 3 hours but there is no actual specification for the maximum size of the hard drive the laptop can be equipped with. Thanks.
The Darkened Phantom(With some light shining through)
CPU: I7-8700K @4.9Ghz 1.313 V Core
COOLER: Corsair H115i
GPU: 1070 Founders Edition @Stock settings
RAM: 16GB DDR4 CL14 TEAM GROUP DARK PRO 8PACK Hand picked Samsung B-Dies @ 3200mhz
PSU: Corsair RM 850X
CASE: Enthoo Pro M Special Edition
STORAGE: 1X 128GB SSD, 1X120GB SSD, 1 X 500GB NVME PCIE SSD and 1X 2TB HDD
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/
There won't be a spec.  Hard drives are handled by the OS, which in a 64 bit OS is a super quadrillion zillions (or near).  Just put in the largest that fits that form factor.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11556299
I'm trying to find what form factor will fit... There is no maximum size in mm listed..
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11556303
Oh, you mean physical size?  M.2 and physical is all I am finding so far.
What's the numbers after the hyphen?  Like this is the FX503VM-NS52...
https://www.newegg.com/Product/Product.aspx?Item=N82E16834234951
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11556314
Yes, they all seem to have an M.2 SSD and/or 2.5" HDD...
https://www.asus.com/us/Laptops/FX503/specifications/
Rip that sucker open and see what's in it, is my recommendation.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11556324
7 hours ago, DrBonesMcCoy said:
maximum size
How big you want to install? Usually laptops can accept up to 4TB of 2.5 inch HDD
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11557377
Either a 1tb or 2tb hdd.
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558188
You're fine
Desktop specs:
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558192
1 minute ago, ZM Fong said:
You're fine
Well I know you can get drives in that capactiry. My problem is I don't know the maximum supported height.
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558193
7mm
Desktop specs:
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558197
2 minutes ago, ZM Fong said:
7mm
Where did you find that? I've been looking and I am unable to find the maximum drive height.
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558200
Most laptops support 7mm 2.5 inch drive
Desktop specs:
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558208
Well I don't need most laptops. I am trying to find the max height. There is a drive that is 9.5mm which would be perfect if I could find the maximum drive height of this chasis.
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558212
FX503 doesn't support anything besides 7mm
Desktop specs:
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558219
got a link?
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558221
8 minutes ago, DrBonesMcCoy said:
got a link?
I don't have a link
I can't confirm 100% that it doesn't support 9.5mm drive, but I'm pretty sure it can't. Laptop nowadays rarely support those form factors especially thinner ones
Desktop specs:
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558237
Again, open it up.  You're going to have to do that to put a new drive in anyway.
Nothing beats actually measuring something.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/950124-fxv03vm-upgrade-help/#findComment-11558308
