I have no idea when, but a while back, the VGA LED on my motherboard (Asus Z170AR) would turn on after booting up the system. It would always work fine, but the light never went off. Recently my computer had just been acting weird so I reinstalled Windows and noticed this time it wouldn't move past the graphics card in boot. I took the card out and everything turned on and installed fine, however, I can't really get much done without a graphics card. I'm really confused about it, as I was using the card a few hours ago, reinstalled and now it just doesn't work. Would anyone know what this might be? Also, additional info, I used to get a lot of Blue Screens from memory related things but they all seemed to disappear before I noticed the light. Not sure if they're tied.
Specs.
Motherboard: Asus Z170AR
Processor: Intel i5-6600K
Graphics Card: Sapphire R9 380 4GB Nitro-DualX OC
Crucial Ballistix Sport DDR4 -2400 (2 x 4GB)
https://linustechtips.com/topic/949475-graphics-card-light/
With the card installed, clear your CMOS on the motherboard (usually involves shorting two pins by touching them both with a screwdriver or other metal object). Google how to do it on your particular board or read your motherboard manual to find where the CMOS or CLR_CMOS is. Report back if it still doesn't post/boot.
Willing to bet that'll fix the issue.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/949475-graphics-card-light/#findComment-11550598
Specs.
if everything else fails try using another computer to reflash the bios on the gpu
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/949475-graphics-card-light/#findComment-11550672
Sadly, that didn't get it to work. Did it both with and without the card and with and without the CMOS battery. I know the clears worked cause it did its turning on and off thing. When the HDMI cable is plugged in, the light turns on, but when its unplugged nothing happens through integrated graphics. Also, I tried the second slot and same thing.
https://linustechtips.com/topic/949475-graphics-card-light/#findComment-11551954
