ETHERNET CONNECTION
Go to solution Solved by TheSLSAMG,
3 minutes ago, Andylxn said:
There's the problem. Ethernet drivers aren't installed. You will need to download this file from ASUS' website, unzip it and install it using the bundled installer. Since your new PC has no internet access, you will need to use another PC to download the file and a flash drive to move it over.
Also, is that Windows 8.1 by any chance? Because that looks suspiciously like Windows 8.1.
Check if Ethernet drivers are installed and working by opening Device Manager and looking for any unrecognized devices. Post a screenshot of Device Manager if you are not sure.
https://linustechtips.com/topic/949081-ethernet-connection/#findComment-11546748
https://linustechtips.com/topic/949081-ethernet-connection/#findComment-11546764
Yeah this is windows 8.1. Sorry but just another question than, I have the windows on a usb; is there a way to unformat the usb so I can use it as an usb than?
https://linustechtips.com/topic/949081-ethernet-connection/#findComment-11546768
You shouldn't have to reformat it, since Windows flash drives don't use special formatting in the first place. If you want to format it though, all you have to do is plug it into a PC, right click it in File Explorer, click format, set it to whatever file system you want (FAT32 is fine, default allocation size) and hit Start in the dialog box.
https://linustechtips.com/topic/949081-ethernet-connection/#findComment-11546778
got it to work tysm
https://linustechtips.com/topic/949081-ethernet-connection/#findComment-11546790
1 minute ago, Andylxn said:
got it to work tysm
You're welcome, happy I could help :D
https://linustechtips.com/topic/949081-ethernet-connection/#findComment-11546793
