Help inserting ram ...
Go to solution Solved by BlueChinchillaEatingDorito,
2 minutes ago, Random_User123 said:
This is the only thing in the manual related to this.. ;-;
Use slots A2 and B2.
6 minutes ago, Random_User123 said:
Put my ram in for best performance, so that it's dual channel it's a 2x4 gb stick.
Check your motherboard manual. Often times, RAM slots are colour coded so for dual channel operation, populate the two slots of the same colour (again, could be different but this seems to be the most common scheme).
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/948929-help-inserting-ram/#findComment-11545320
https://linustechtips.com/topic/948929-help-inserting-ram/#findComment-11545325
https://linustechtips.com/topic/948929-help-inserting-ram/#findComment-11545328
Thanks!
Hopefully that works. That manual seems very... odd. Which brand and model is it?
https://linustechtips.com/topic/948929-help-inserting-ram/#findComment-11545336
