Laning D5 with the variable RPM function, 7 volt fan adapters, generally fat radiators, and of course silent as possible fans.
if you want radiator advice you need to tell us what case you have so we can try to find a suitable radiator thickness & size
https://linustechtips.com/topic/94889-silent-components/#findComment-1271499
