i planning on buying a sony 4k camera capturing from it and to capture some of my 3d animation in 4k and i really don't know that much about capture devices that dose this so i need help picking one up
i don't want a over the top device more in the level of a pro-consumer with a little bit more emphasis on the pro part
https://linustechtips.com/topic/94861-4k-capture-devices/
Basically, you want to capture 4K video outside of your computer and you would also like to render 3D animations into 4K? I do not see where you would need a second 4K capture device other than the Sony 4K Camera to do this. Unless of course, you want to record yourself doing some 3D modeling in 4K. In that case, I found this 4K capture card. http://www.bhphotovideo.com/c/product/892446-REG/Blackmagic_Design_bdlkhdextr4k_DeckLink_4K_Extreme.html
You will need some pretty beastly graphics horsepower to be able to run the 4K output from your graphics output to the linked capture card.
widget.png?style=banner2
PC: 9800X3D, 96GB Trident Z5 6200 CL28, 5090 FE, 3.84TB CM7
NAS: Xeon W-2195, 256GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale
https://linustechtips.com/topic/94861-4k-capture-devices/#findComment-1271145
how about a k6000 for the gpu horse power
https://linustechtips.com/topic/94861-4k-capture-devices/#findComment-1271160
this is the camera http://www.amazon.com/Sony-FDRAX1-Camcorder-Optical-3-5-Inch/dp/B00EVIJXBO/ is this model compatible with the capture card
https://linustechtips.com/topic/94861-4k-capture-devices/#findComment-1271165
I understand now... So you want something to allow you to record from that camera straight to your computers hard drive? In that case, scrap what I said before. I believe that the camera records to a media card as stated here
The AX1 uses XQD media cards for smooth, high-speed reading and writing of 4K video and features two XQD media slots.
A relay recording feature makes it possible to lengthen recording by automatically switching between two or more media.
The AX1 is compatible with following types of XQD media cards:
XQD media card S-series
XQD media card H-series
XQD media card N-series
So i'd look into buying a XQD media card reader or USB Adapter for your computer such as this. http://www.amazon.com/Sony-Memory-Reader-MRWE80-BC1/dp/B0074AWVPG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1388304890&sr=1-1&keywords=xqd+card+reader
https://linustechtips.com/topic/94861-4k-capture-devices/#findComment-1271185
  • 1 month later...
