This is the build I plan on making please give me some feedback.
-ASUS GeForce GTX 680 DirectCU II TOP Edition
-ASUS P8Z77-V DELUXE Motherboard
-Intel Core i7 3770K
-Thermaltake EVO Blue 2.0 750W
-Corsair Neutron Series 128GB SSD
-G.Skill Ripjaws 16gb
-Corsair Hydro Series H100i CPU Cooler
-Some LG optical drive with random name
-Razer Mamba
-Keyboard to be decided
-Razer goliathus mouse pad.
https://linustechtips.com/topic/9476-my-build-plan/
I'm not going to sit here and tell you to change this and that because it isn't good for x reason as I can see you've got the money and you want an above average system for whatever it is. Looking forward to seeing the end result and if you have the time, why not post a build log of it?
https://linustechtips.com/topic/9476-my-build-plan/#findComment-103716
It looks good, don't worry about the sli 670's though :/
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/9476-my-build-plan/#findComment-103725
