I have just started getting BSODs every now and again normaly after playing for a while, this made me think that it could be my temps but my cpu and gpu have been at normal temps, one of the BSODs i got was called "UNEXPECTED_KERNAL_MODE_TRAP"  Also thought that it could be drivers but i dont know what one it would be is there any good driver scanning software that isnt a scam?  This only started happening after playing for a while also it has been pretty hot in recently but temps seem fine, i really dont know ¯\_(ツ)_/¯ any one have an idea?
https://linustechtips.com/topic/945740-bsod-fix/
I have been getting the same problems too and I have gotten multiple different errors :/ i dont really know what to do but I have started a post on it with a couple troubleshooting ideas too if you want to check it out.
We may not have the same problems tho. You could try this.
Open files>right click This PC>Properties>click System Protection on the right>Advanced>Startup and Recovery>Settings...
And then copy the settings in the picture. Then, when your pc crashes, go to files>local disk>windows>minidump then go to http://www.osronline.com/page.cfm?name=Analyze
and upload that file and when it finishes, go to the bottom and look at the "image name:" and then copy that and look it up on google and you might find a solution.
https://linustechtips.com/topic/945740-bsod-fix/#findComment-11515862
