So I recently finished building a PC with parts I strung together from ebay and local used sites (and also what parts I already had lying around) and I managed to  build an alright little system. The specs are an i5 3330 CPU, 8gb ddr3 1866mhz ram, an HD 7770 gpu, and an asus  P8H61-I LX R2 motherboard. Now after 2 attempts of installing windows 10 (first try ended with a boot error after 2 days) I finally have it working with a lot of my steam library already installed. The problem I've discovered is I cannot get the system to restart in any way, the system can shut down fine but if I restart the PC through windows, through the bios or even with the physical reset switch on the case the screen goes black, all the fans spin to 100% and it refuses to do anything until I cut off the power. The system powers up okay but because i cant restart/reset the PC so I cant save any changes in the bios such as ram speed changes. Frankly I'm stumped, anyone ever had this issue and or a possible fix? Thanks
https://linustechtips.com/topic/945515-weird-restart-issue/
That motherboard has had awfully many system stability improving BIOS versions.
https://www.asus.com/Motherboards/P8H61I_LX_R20/HelpDesk_BIOS/
So is BIOS even remotely latest?
Anyway with that old parts there could be plenty of things which are starting to wear down.
BIOS battery would be also one thing I would replace.
https://linustechtips.com/topic/945515-weird-restart-issue/#findComment-11514196
