Hey guys, i bought a new PC
I have a I5 8600K but i didnt get a GPR yet since i am waiting for the new series
I was wondering if it is possible to connect 2 monitors (Samsung- C24F390FHU) to the integrated graphics card without overloading it and probably damage the CPU. I wanted to play and see youtube a the same time and that is why i wanted the dual monitor
Thanks
https://linustechtips.com/topic/945460-will-it-be-too-much/
No way I can see it hurting anything, so no risk in trying.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
https://linustechtips.com/topic/945460-will-it-be-too-much/#findComment-11513461
5 minutes ago, Brian Reis said:
About lowering the settings, i dont know if it is needed since its just to play league of legens and the cpu hasnt gone over 45 degrees so far
Then your golden. I should have elaborated that you would need to lower your settings to play at a reasonable framerate for games more demanding than LoL, like Ghost Recon Wildlands, or something similar.
https://linustechtips.com/topic/945460-will-it-be-too-much/#findComment-11513482
Thank you a lot for your help, i will connect the monitors and keep tracking my temperature while gaming just to make sure all goes well
https://linustechtips.com/topic/945460-will-it-be-too-much/#findComment-11513493
