i have an samsung tablet from like... 4 or 5 years ago and dont use it cause its slow and i have a S8+
i want to get into drawing or just digital art in general i always wanted to draw
i am wondering for when im on pc can i use my tablet as a "drawing pad" on my pc? or no? im cool with hooking a usb up to it and having to do stuff to it if i have to but i just want to know
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
https://linustechtips.com/topic/945440-using-tablet-for-digital-art/
I'm digging through archives right now, but there was a way I did this a couple years ago and it worked alright (no pressure sensitivity and just a light bit of lag). Unfortunately the app seems to be discontinued but I found an APK and stuff so I'll edit this with instructions/links as soon as I get it figured out
edit:
K so Step 1 is to install Java SE Runtime (if you don't already have java installed): http://www.oracle.com/technetwork/java/javase/downloads/jre8-downloads-2133155.html
Step 2: you'll need the Slide (the name of this app) APK, because the app isn't on the play store anymore. I put it on my google drive, here: https://drive.google.com/open?id=1ompk6dW9rt2b_5BsZnCUYc_TQp2yDumA . You download this file then run it, and it'll install. If it doesn't let you install it, you'll have to go into your settings and allow apps from unknown sources.
Step 3: Since you said it was a Samsung tablet, you'll need Samsung's Spen SDK, which fortnately is on the app store: https://play.google.com/store/apps/details?id=com.samsung.android.sdk.spen30&hl=en_US
Step 4: You'll need the Windows app. https://drive.google.com/open?id=1rmAsMjprOiuP1xUeE_ur0nKxrzRl0fFY . You run this normally (it'll work if you have the Java Runtime installed).
Step 5: make sure the tablet and Computer are on the same Wifi network
Step 6: Launch the Slide app on your tablet. Press next when it says to go to some site (that site is down and has been for a year). Go to connection mode and select Wifi. If "Automatically detect server" is unchecked, check it.
Step 6: press Connect on the android app
If nothing went wrong, the screen on your device should be solid white and if you move your finger around the screen, your cursor should move too. The controls are:
Tap = Click
Double Tap = Double Click
Double Tap and Hold = Clicking and holding (lets you drag the cursor).
Tap and hold: Right click (you have to enable it on the app, go down to controls and check Right Clicking).
Drag 3 fingers: scroll (also have to enable in controls)
Apparently there is pressure clicking, but idk how to set those up or if they were even developed.
If you have any problems, I might have solutions.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
edit:
Tap = Click
k im working on it now
RAM: 32gb ddr3
2 hours ago, Sayori said:
-snip-
It works
RAM: 32gb ddr3
