Hi all,
Currently I am look at building a new computer for around $700 AUD
I have specific requirements that must be met.
REQUIREMENTS:
·         Have support for a dual monitor setup
·         Ability to be upgraded in the future
·         Can run CAD/CAM software
·         Must be able to play most games at a reasonable frame rate (60-90FPS)
·         Doesn’t not need to include peripherals
·         Must have at least 3-4 pci slots
It is something that is needed urgently as his birthday is in 4 weeks.
https://linustechtips.com/topic/945249-help-with-building/
if you can stretch the budget:
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor  ($159.00 @ BudgetPC)
Motherboard: MSI - H310M PRO-VD Micro ATX LGA1151 Motherboard  ($82.98 @ Amazon Australia)
Memory: Team - 8GB (1 x 8GB) DDR4-2400 Memory  ($109.00 @ Umart)
Storage: Team - L5 LITE 3D 120GB 2.5" Solid State Drive  ($45.00 @ Mwave Australia)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.00 @ Shopping Express)
Video Card: Inno3D - GeForce GTX 1050 2GB Compact Video Card  ($150.00 @ Umart)
Case: Thermaltake - Versa H18 MicroATX Mini Tower Case  ($49.00 @ Mwave Australia)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($65.00 @ Shopping Express)
Total: $713.98
Generated by PCPartPicker 2018-07-07 21:37 AEST+1000
https://linustechtips.com/topic/945249-help-with-building/#findComment-11511786
12 minutes ago, Ethan Cahill said:
Hi all,
REQUIREMENTS:
for $520 US i really don't think you can get 60-90fps unless you play on the lowest graphics settings but you can do CAD as long as the drawings dont get too big. 3-4 pci slots will be hard but it is possible, dual monitor setup is basically almost always there, no worries on that. and yes it will be upgradable. if you can squeeze out around 200-300 more aud, you can get a pc which will meet all your requirements but for $520 us you cant get it to meet all of that
https://linustechtips.com/topic/945249-help-with-building/#findComment-11511787
