If i don't move the mouse for a period of time ( 4 to 4:30 seconds ) system uses up 100% cpu. The temperature changes by 5C sometimes stays the same.
If i move the mouse or click the cpu utilization drops to a normal 1% to 10%
dust was cleaned 2 weeks before the problem started
thermal paste was changed 1 month ago
video-1530555689.mp4
https://linustechtips.com/topic/943672-system-uses-up-100-cpu/
open taskmanager,sort by cpu usage and wait until it kicks in to see what program uses that much
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/943672-system-uses-up-100-cpu/#findComment-11497395
30 minutes ago, Lexabord said:
Could be that you're infected with a miner that only activates while idle?
did you already try reinstalling your OS?
https://linustechtips.com/topic/943672-system-uses-up-100-cpu/#findComment-11497397
