Fan Orientation. Help Needed.
Solved by userzero,
Sorry but what specs are you running? You don't need all of this as a regular user unless you're overclocking some serious hardware in there.
Whatever you do just make sure you have slightly more exhaust than intake, quite simple mate ![]()
And yes, all the filters you can on intakes is good.
Vibora ·
Posted in New Builds and Planning3 -
4
3
Doctah ·
Posted in Peripherals2 -
6
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards5 -
Packhunter ·
Posted in Graphics Cards6
