Hello
Recently I've been having problems with my PC. It keeps buffering and sometimes freezing for a couple of seconds. I've had my pc for 4 months now and there have been no problems
I have a
Ryzen 5 1600x
1050ti
8gb ram
250gb ssd
Msi b350 motherboard
   I've adjusted the settings in the Nvidia control panel.
Any help is very welcomed
https://linustechtips.com/topic/942685-low-fps-on-good-pc/
2 minutes ago, iHacki44 said:
Hello
I have a
Ryzen 5 1600x
1050ti
8gb ram
250gb ssd
When does it (or what causes it) buffer? Does it Blue screen? Have you updated windows recently? Have you updated any drivers? (Nvidia, etc) Have you checked Task manager to see if there is a spike in GPU, CPU or disk usage?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/942685-low-fps-on-good-pc/#findComment-11488647
What do you call "Low" Fps?
I almost have had the same build as you, Minus I had 16Gb of ram When I had my 1050ti.
But, The 1050 really lacks when playing higher end games, I also would get below 60FPS in most games, Plus you have only 8gb of ram that could effect FPS alot.
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/942685-low-fps-on-good-pc/#findComment-11488666
I have no idea whats the reason for buffering. It doesn't blue screen. When I open task manager it shows me what it should(normal cpu usage). No big spikes
https://linustechtips.com/topic/942685-low-fps-on-good-pc/#findComment-11488733
Woops. Wrote without thinking too much. I get 150 fps in csgo and I now that's a lot but it keeps buffering and gives you the inpression like youre plating with 20 fps. Plus it keeps shifting from 100 to 200. I would prefer to play with 60fps all the time constant than this
https://linustechtips.com/topic/942685-low-fps-on-good-pc/#findComment-11488756
