Good afternoon all (from NYC)
im new here so first I would like to say hello!
i am in need of some help.
I have a intel server board: s1200v3rp
with a Intel G41024-612 MegaRaid module
8gb ram(don’t recall the exact model)
and three: Seagate ES.3 ST4000NM0033 4TB
i am not able to boot via a usb drive and I am locked out via bios password.
i wanted to clear the bios(reset) but I didn’t find the clear cmos pins.
Any help would be LD be highly appreciated!
https://linustechtips.com/topic/942662-need-some-help/
CPU - i5-8400 , Motherboard - ASROCK Z370 Killer SLI, RAM - 2x8 GB DDR4 2400mhz , GPU - EVGA GTX 950 SC, Case - SilentiumPC PAX M70 Pure Black V2 Storage - 240GB SanDisk SSD, 1TB WD Blue, PSU - bequite! 600w Pure Power 10, Display - Dell P2417H, Cooling - bequiet! Pure Rock, Keyboard - Viper V730, Mouse - natec Genesis G55, Sound - Philips MCD712, OS - Windows 10 Professional 64-bit
https://linustechtips.com/topic/942662-need-some-help/#findComment-11488442
Also, the CMOS and clock is tied to the Button Battery (BB).  You can power off the system, remove the battery, short the battery connectors for about 10 seconds, plug the battery back in, and power it on.  The only downside is you'll have to reset the BIOS clock and date, and possibly change a few BIOS settings.
https://linustechtips.com/topic/942662-need-some-help/#findComment-11488457
Hello CMaderaTM
You can also try turning off the bios battery for the night, in the morning turn on the server and BIOS should load the latest version.
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/942662-need-some-help/#findComment-11488471
