Hello I have a problem with my rig. It keep restarting when under load I have already tried new ram new CPU new board new had. And it's still doing it. I have got to the point where I have built 2 rigs one has a fx 8350 16 gigs ddr3 r9 290 gpu and the other is a fx 6300 16 gigs ddr3 with a 970 ti and they both reset every time under load what do I do
https://linustechtips.com/topic/941716-need-help/
Is the PSU the same under both? To me that seems like the only constant, and would make a heck of a lot of sense, especially if it's an "El Cheapo" PSU.
COMPUTER: Mobile Battlestation  |  CPU: INTEL I7-8700k |  Motherboard: Asus z370-i Strix Gaming  | GPU: EVGA GTX 1080 FTW ACX 3.0 | Cooler: Scythe Big Shuriken 2 Rev. b |  PSU: Corsair SF600 | HDD: Samsung 860 evo 1tb
https://linustechtips.com/topic/941716-need-help/#findComment-11479202
Could be overheating or a faulty PSU.
-Moved to Troubleshooting-
https://linustechtips.com/topic/941716-need-help/#findComment-11479203
I was asking about the Power supply, not the CPU.
https://linustechtips.com/topic/941716-need-help/#findComment-11479236
2 minutes ago, Nasa34 said:
Oh oops noob moment both psu are 750
Okay, so you're using different PSUs for each?
To help prevent a lot of back and forth on each, please do the following:
  • List out all the components (with specific model numbers) in each machine
  • List of symptoms and when it started happening
  • List all the troubleshooting steps you've gone through so far
As for the different ATX power headers on the motherboard, that is for extra power delivery to the CPU. It started off as an additional 4-pin, and as CPUs became more powerful, they moved up to an 8-pin. Lower-end boards assume lower-end (read: less power hungry) CPUs, and cut costs by limiting the power delivery.
https://linustechtips.com/topic/941716-need-help/#findComment-11479273
