Hey Gang
I think I might be having a few issues with a system I decided to overclock after having run at stock setting for 3 year (LOL).
The Temps on the CPU are kind of worrying me as the idle temps are 48-50 and when I run prime95 the CPU temps BOLTS up to 90+ in less than 2 mins and I stop the test at that point. (I'm scared I'll Kill the CPU :P)
I wanted to get some feedback on if these setting are good or can I improve the temps by making a few adjustments.
Here are my specs and OC settings, I hope I've included all the neccessary info.
i7 950 @ 3.02 (4.01 overclocked)
Gigabye GA-X58A-UD3R rev 2.0
Coolermaster Silent Pro Gold 1200W psu
Noctua NH-U12P SE2 CPU cooler (Push/Pull Config)
Corsair XMS3 — 12GB Triple Channel DDR3 Memory Kit (CMX12GX3M3A1600C9) 9 9 9 24
Rating: PC3-12800 (1600MHz)
WESTERN DIGITAL 1TB 3.5" BLACK 64MB SATA3 WD1002FAEX
WD 500GB HDD x 3 (Storage Only)
EVGA GeForce GTX 580 Superclocked 1536 MB GDDR5 PCI Express 2.0
Creative X-Fi Titanium Fatal1ty Pro
CPU Clock Ratio............................:20
CPU Frequency .....(Ghz)...................:4.0
Intel® Turbo Boost Tech..................:[Disabled]
CPU Cores Enabled..........................:[All]
CPU Multi Threading........................:[Enabled]
CPU Enhanced Halt (C1E)....................:[Disabled]
C3/C6/C7 State Support.....................:[Disabled]
CPU Thermal Monitor........................:[Enabled]
CPU EIST Function..........................:[Disabled]
Bi-Directional PROCHOT.....................:[Enabled]
Virtualization Technology..................:[Enabled]
Uncore & QPI Features [Press Enter]
QPI Clock Ratio*...........................:36
QPI Link Speed* ......................(Ghz):7.20
Uncore Clock Ratio.........................:x17
Uncore Frequency......................(Mhz):3,4
Isochronous Support........................:[Enabled]
Base Clock (BCLK) Control*.................:[Enabled]
BCLK Frequency (Mhz)*......................:200
PCI Exxpress Frequency (Mhz)...............:103
CPU Clock Drive (mV).......................:700
PCI Express Clock Drive (mV)..............:700
CPU Clock Skew (ps)........................:0
IOH Clock Skew (ps)........................:0
Performance Enhance........................:[standard]
Extreme Memory Profile (X.M.P.)............:[Disabled]
System Memory Multiplier (SPD).............:x8
Memory Frequency (Mhz).....................:1,600
DRAM Timing Selectable (sPD) ..............:[Quick]
Channel A, B, and C Standard Timing Control
Cas Latency Time.............................:9
tRCD.........................................:9
tRP..........................................:9
tRAS.........................................:24
(All sub-timings on Auto for all 3 channels)
LoadLine Calibration.........................:[Level 2]
CPU Vcore....................................:1.325v
QPI/VTT Voltage..............................:1.275v
CPU PLL......................................: 1.80v
PCIE.........................................:1.50 v
QPI PLL......................................:1.10v
IOH Core.....................................:1.10v
ICH I/O......................................:1.50v
ICH Core.....................................:1.10v
DRAM Voltage.................................:1.64v
DRAM Termination.............................:[Auto]
Ch-A Data Vref...............................:[Auto]
Ch-B Data Vref...............................:[Auto]
Ch-C Data VRef...............................:[Auto]
Ch-A Address Vref............................:[Auto]
Ch-B Address Vref............................:[Auto]
Ch-C Address VRef............................:[Auto]
Intel i7 950 @ 3.07 runing @ 4.01 / Gigabyte X58A UD3R Rev 2 / Corsair 12GB DDR3 Memory / Evga GTX 580 SC / Coolermaster CM 690 II (ver.2) / WESTERN DIGITAL 1TB 3.5" BLACK 64MB SATA3 / Coolermaster Silent Pro Gold 1200W
Samsung Syncmaster S27B370 / Noctua NH-U12P (Push/Pull Config) / MS Digital media Keyboard 3000 / Logitech G5 / Sound Blaster X-FI Titanium
https://linustechtips.com/topic/93993-overclocking-help-i7-950/
Hi, I'm running my 920, which is a very similar chip to yours, at 3.8 GHz.
My BCLK is 180, voltage 1.3 something
Idle temp: 47-50 C
Load(prime95, blend test): 75-79 C
If I try 4 GHz, I also get 90 C +, but I guess my cooler is much worse than yours (Akasa Nero 3).
Check this one out, too.
http://www.overclock.net/t/538439/guide-to-overclocking-the-core-i7-920-or-930-to-4-0ghz
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/93993-overclocking-help-i7-950/#findComment-1261606
Thanks Juretin
I read that Piece when I was doing the overclocking. What i wanted to know more or less is if these setting are fine given the Temps I'm hitting and to tweek them if needed.
https://linustechtips.com/topic/93993-overclocking-help-i7-950/#findComment-1264174
I also Scrwed up....................OMFG and not what is posted in first post.........................WHAT A NOOB I AM
my Current Setting are:
My Current OC Setting are:
 CPU Clock Ratio..................:23
CPU Frequency .....(Ghz).....:3.91
Intel® Turbo Boost Tech.....:[Disabled]
CPU Cores Enabled.............:[All]
CPU Multi Threading..........:[Enabled]
CPU Enhanced Halt (C1E)...:[Disabled]
C3/C6/C7 State Support.....:[Disabled]
CPU Thermal Monitor........:[Enabled]
CPU EIST Function..............:[Disabled]
Bi-Directional PROCHOT.....:[Enabled]
irtualization Technology.....:[Enabled]
QPI Clock Ratio*................:36
QPI Link Speed* ................(Ghz):6.12
Uncore Clock Ratio............:x17
Uncore Frequency.............(Mhz):2890
Isochronous Support........:[Enabled]
Base Clock (BCLK) Control*...........:[Enabled]
BCLK Frequency (Mhz)*................:170
PCI Exxpress Frequency (Mhz)......:Auto
CPU Clock Drive (mV)................:700
PCI Express Clock Drive (mV)....:700
CPU Clock Skew (ps).................:0
IOH Clock Skew (ps)..................:0
Performance Enhance...........................:[standard]
Extreme Memory Profile (X.M.P.).........:[Profile 1]
System Memory Multiplier (SPD)..........:x8
Memory Frequency (Mhz).....................:1,600-1,360
Cas Latency Time.......:9
tRCD...........................:9
tRP.............................:9
tRAS...........................:24
LoadLine Calibration.........:[Level 2]
CPU Vcore....................1.25000v....:[1.31875v]
QPI/VTT Voltage...........1.175v...:[1.275v]
CPU PLL.........................1.800v...:[1.800v]
PCIE.........1.55v.....:[Auto]
QPI PLL.....1.100v....:[1.100v]
IOH Core.... 1.100v.:[1.100v]
ICH I/O.......1.500v...:[1.500v]
ICH Core.....1.100..:[1.100v]
DRAM Voltage........1.500v......:[1.660v]
DRAM Termination.0.750v.....:[Auto]
Ch-A Data Vref......... 0.750v....:[Auto]
Ch-B Data Vref.......... 0.750v...:[Auto]
Ch-C Data VRef........ 0.750v....:[Auto]
Ch-A Address Vref.... 0.750v...:[Auto]
Ch-B Address Vref...... 0.750v.:[Auto]
Ch-C Address VRef..... 0.750v..:[Auto]
https://linustechtips.com/topic/93993-overclocking-help-i7-950/#findComment-1266936
