I need new pc and im on budget around 550-600$ max
And i saw a pre-built pc for around 493$
Here are the specs :
Gpu - gtx1050
Cpu - ryzen 3 1200
Ram - 8gb ddr4 2400mhz
Motherboard-A320M
1TB of HDD memory
and 500W psu
So i would use it for "Lite gaming" playing games such as csgo,7 days to die,dead by daylight,rocket leaguea etc.
Im not rly into games that need rly good cpus and gpsu to run it nicely such as witcher 3,battlefield 1,crysis 3
Only more demanding game i would play is pubg which should get between 50-60fps which i would be fine with
Now i understand for that money i aint getting to much,but i think its good thing to start of and later on when i save up money just upgrade that pc.
So i would like to hear opinion from someone else and im open to  suggestions
Also i was thinking of building the pc myself,but in order to achive better it would cost me 750$+ which is not the option rn
https://linustechtips.com/topic/939233-need-help-with-new-pc/
My only concern with that prebuilt is the lack of SSD. It's going to feel every slow, because the boot drive will be an HDD.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/939233-need-help-with-new-pc/#findComment-11456502
I would actually go intel for this one. Go for the 8th gen i3 (8100) and the MSI Pro Series Intel B250 LGA 1151. You can use all the other parts. Your performance would be better for gaming. You would also need to get a cooler ($20-$25) as I don't believe that cpu model comes with one.
https://linustechtips.com/topic/939233-need-help-with-new-pc/#findComment-11456512
https://pcpartpicker.com/list/9Pp2kd
All within your budget, includes a ssd and a hdd for storage, 3000 memory vs 2400, and its a better graphics card with a 1050ti vs a standard 1050.  Oh and the cooler is included.  I build many of these systems for the budget gaming rig, and will play more demanding titles as well.
R7 5800x -:- Asus ROG Strix X570-F Gaming -:- EVGA FTW3 Ultra RTX3080 -:- EVGA 850 GA -:- 32GB G.Skill TridentZ Neo  -:- Asus TUF GT501
https://linustechtips.com/topic/939233-need-help-with-new-pc/#findComment-11456529
CPU: AMD - Ryzen 3 1300X 3.5GHz Quad-Core Processor  ($124.99 @ Amazon)
Motherboard: ASRock - A320M Micro ATX AM4 Motherboard  ($54.99 @ Amazon)
Memory: Patriot - Signature Line 8GB (2 x 4GB) DDR4-2666 Memory  ($78.99 @ Amazon)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($36.99 @ Amazon)
Storage: Hitachi - Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive  ($39.99 @ Amazon)
Video Card: PNY - GeForce GTX 1060 3GB 3GB Video Card  ($229.00 @ Amazon)
Case: Rosewill - SCM-01 MicroATX Mini Tower Case  ($26.99 @ Amazon)
Power Supply: BitFenix - Formula Gold 550W 80+ Gold Certified ATX Power Supply  ($69.00 @ Amazon)
Total: $660.94
Generated by PCPartPicker 2018-06-19 13:29 EDT-0400
Shits about to blow up with this build :). By that I mean FPS, not your PC lol.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/939233-need-help-with-new-pc/#findComment-11456553
1GB less VRAM with the 1060 3GB but a whole ton more performance :) Here's my build vs @ad1das's build on UBM. Keep in mind this is based on AVERAGE PERFORMANCE of the components listed. Had to use a 2TB drive in my list on UBM due to the 1TB model not being listed, performance should not be affected by alot (if at all).
https://linustechtips.com/topic/939233-need-help-with-new-pc/#findComment-11456573
i3 build wouldn't really be worth the performance boost against the build I posted.
https://linustechtips.com/topic/939233-need-help-with-new-pc/#findComment-11456590
I haven't seen your build yet, but I'm sure. Keep in mind though, he is needing to buy a PSU, so I don't know if adding that on to what you posted would get him closer to his budget. I'd also recommend a single stick of 8GB for ram, so to leave him more room to expand. The i3 I suggested gets about the same speeds and overclocks quite well. It's been quite reliable for me so far.
https://linustechtips.com/topic/939233-need-help-with-new-pc/#findComment-11456607
1 hour ago, Srbin said:
For those builds,can those parts be shipped to Serbia and would that cost(if so how much)
I have no idea, but I suppose you could check it out by checking where they ship to on the site.
https://linustechtips.com/topic/939233-need-help-with-new-pc/#findComment-11456975
It's a couple posts up, a single stick of 8GB would be a terrible idea as they couldn't use dual channel mode, dual channel mode is more efficient than single channel so it's favoured over a single channel 8GB stick. The PSU I suggested should do him fine, good quality PSU with the great feature of it being FULLY modular. Keep in mind that my price would only be higher than intel if you chose the cheapest board on the market which would be totally unadvisable. Idk how you're managing to overclock that 8100 either, it's a locked chip (non K variant).
https://linustechtips.com/topic/939233-need-help-with-new-pc/#findComment-11456983
