I have been having this problem for a few weeks now. I turn on my computer and after about 5-10 minutes all of my monitors turn a random color, usually a green or a grey, and the computer completely freezes. The only way to stop it is to completely power her down. I've taken out and reseated literally every component and swapped all all the monitor cables and this still happens. If i have music playing that freezes as well, so this lets me think it isn't a problem with the displays or the graphics card. Regardless if I open any programs or not, this still happens. Any advice would be appreciated.
Specs:
FX 8350
EVGA 650W gold
4x4 crucial ballistix sport
Sapphire Radeon RX 470 turbo 8gb
970a-DS3p motherboard
1TB WD Black hard drive
Cryorig H7 cpu cooler with ample case fans (cooling isn't the problem, I've monitored the temps while it happens and the CPU and the GPU both idle around 30C)
https://linustechtips.com/topic/937972-need-help/
Sounds a lot like a GPU issue. When you say the monitors turn a random color do they still display what was on screen or does it start to look like static?
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
https://linustechtips.com/topic/937972-need-help/#findComment-11445540
They literally become one solid color as in the entire monitor becomes solid green and whatever sounds that were going on freeze and repeat. No image is displayed just one solid, static color.
https://linustechtips.com/topic/937972-need-help/#findComment-11445546
I am 99% sure that is an issue with your gpu. If you have a warranty you should look into getting a replacement
The Impossibox
WhisperingKnickers
x58 Fan Page
https://linustechtips.com/topic/937972-need-help/#findComment-11445550
2 minutes ago, WhisperingKnickers said:
I am 99% sure that is an issue with your gpu. If you have a warranty you look into getting a replacement
I still have the old GPU that i upgraded from and that one still works fine so I'll swap it in and see if the issue persists.
https://linustechtips.com/topic/937972-need-help/#findComment-11445557
2 minutes ago, partuchi said:
Ok Ill look at getting a replacement, thank you
Sorry about the loss, that really sucks
The Impossibox
WhisperingKnickers
x58 Fan Page
https://linustechtips.com/topic/937972-need-help/#findComment-11445559
