Need some help
Go to solution Solved by Hashiba,
Hi @Peacefulgaming,
I think it all comes to a personal taste, I guess most players use non tactile switches, but there are many exceptions, so, my suggestion is to find a place that have a bunch of keyboards and test them, try different models with different switches, cherry mx blacks, reds, browns, blues, clears, etc :)
Hi @Peacefulgaming,
NeXTcube 12400 Z690M ITX 64GB SN770 6600XT Sugo16 12.5
NeXTserver 9400 H310N ITX 32GB SN350 5500XT Fara R1 12.5
NeXTstation 9900K Z390 ITX 32GB SN750 6800XT Enthoo 12.5
https://linustechtips.com/topic/936537-need-some-help/#findComment-11432235
On 12/06/2018 at 1:00 AM, Hashiba said:
Hi @Peacefulgaming,
Alright thank you
https://linustechtips.com/topic/936537-need-some-help/#findComment-11437858
