Socket 478 cooler
Solved by Hashiba,
it's been a very long time since I've used one of those boards, I think you should be able to flex the plastic bracket enough to remove the clip, but if it's stuck maybe you have a board that has screws on the back holding the bracket itself, maybe you can try removing the whole thing, I remember I had to do that on a P4 back in the day in order to install an aftermarket cooler. I hope that helps somehow
