52 minutes ago, Asusfanboy said:
I have a dell G7 15 (7588) with 2 dimms, currently only one is populated with an 8gb stick I am looking to upgrade to 16gb so I need u to recommend me a 1×8 gb stick of sodimm ram BTW I want the best 1×8gb thanks!
It uses 2666MHz DDR4 SODIMMs.  Getting you the 'best' may not be worth it considering the computer will negotiate elements of memory timings and speed based on the slowest DIMM.
Is it possible for you to see what model chip you have in there now?
Otherwise I'd just suggest getting an 8GB 2666MHz DDR4 SODIMM from a reliable manufacturer.
https://linustechtips.com/topic/936448-help-me-upgrade-laptop/#findComment-11431591
