I have never before build a pc from scratch and therefore am I asking for help with choosing my storage.
I want to have a Corsair Force MP500 240GB M.2 NVMe PCIe SSD as my boot drive, but I doubted the chose because I have read it is not possible to do so. So my question is, is it possible to make that Corsair Force MP500 M.2 NVMe PCIe SSD my boot drive?
If it is not possible to use the Corsair Force MP500 as a boot drive, would it then be possible to use Samsung 860 EVO?
I will also mention that it will be a fresh install of windows everything will be completely new.
Parts in my computer listed below.
CPU: AMD Ryzen 7 1800X 3.6 GHz 8 Core
MOBO: ASUS X370-I Gaming
Memory: 16GB Corsair Vengeance LPX DDR4 3000 MHz
GPU: MSI GeForce GTX 1080 Armor OC
PSU: SilverStone SFX Series SX700-LPT
Storage:
As boot drive if possible: Corsair Force MP500 240GB M.2 NVMe PCIe SSD
Big storage: Seagate Barracuda 2TB HHD
OS: Windows 10
Cooler: NZXT Kraken X52
https://linustechtips.com/topic/935558-help-with-choosing-storage/
DOnt buy an 1800x. Buy a 2700. Its a .5 generation upgrade
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
Why?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
6 minutes ago, ToPpeR said:
Well, I don't really need an NVMe for booting, an SSD would also be fine I guess as told I don't know a whole lot about it. So if I understand you right, an SSD would be more than enough for a boot drive?
both of what you are thinking of (SATA and NVMe) are Solid State Drives. one has a much higher throughput, but the latency on both types are nearly identical. response time and boot speeds are perceptually the same.
Honestly, unless you have a use case where you KNOW you need/want NVMe, SATA will do just fine at half the cost (or double the capacity, which effectively doubles the longevity, aka TBW)
System specs:
Okay, I think I understand know. I appreciate the help a lot!
