Hi, I was looking into the cooler master master fan pro rgb and I saw two different voltages, and what do each of them mean, what's the difference between rated current and safety current? If my motherboard's fan header's max is 1A, how many of that fan can i put on one header without it breaking? If I'm going to use a fan splitter, what voltage should I be worried about?image.png.f497e60fe6f3c4f9a70b40b3f4f130d9.png image.png.f497e60fe6f3c4f9a70b40b3f4f130d9.png
https://linustechtips.com/topic/935009-fan-current/
Hi, I’m looking into a cooler master fan and im wondering how many fan can I plug into a fan header, on the specs it said the safety current is 0.37A and the rated current is 0.22A so I assume that the max power it can pull at once is 0.22A and therefore I can put 3 of them on one motherboard fan header right?
https://linustechtips.com/topic/935009-fan-current/#findComment-11418960
Safety current is for your max equipment load
Rated current is for your equipment to use safely without breaking/overheat.
It's ampere & voltage not just voltage, if its require 5v at 0.17a then 0.17a is should be delivered, although it could deliver 0.4a at peak however it should only use 0.17a.
Never goes full load on power all the time, it's like golden rule of powering something.
While your header maxed at 1A, don't use more than 4 fans (0.4a rated) on to it, although it can since the rated current only 0.17a.
https://linustechtips.com/topic/935009-fan-current/#findComment-11418964
As long as the header is rated for 1Amp capacity yes 3 fans would be relatively safe given it only draws a total of 0.66A when running. The reason for the safety current is the sudden current draw when starting the fans which would take around 1.1Amps, a little over the rating of a 1Amp header.
https://linustechtips.com/topic/935009-fan-current/#findComment-11418967
So I should only put 2 fans per header, correct?
https://linustechtips.com/topic/935009-fan-current/#findComment-11418986
Two would be the safest option, I'd personally test the fans to see if it actually peaks that high for the starting current but it's up to you. If you need you can also get a powered fan hubs if they're 4 pin PWM fans.
https://linustechtips.com/topic/935009-fan-current/#findComment-11419003
One more question, if I decide to go with a Corsair fan which does not support aura sync which my motherboard and ram is going to use, will the whole thing freak out? Like stop working. (BTW the Corsair uses a sperate hub and app)
https://linustechtips.com/topic/935009-fan-current/#findComment-11419010
It uses the Corsair Link ecosystem so you will need to control it through that so it will not natively sync. You can see if someone has made a third party SDK to allow for software syncing depending on your motherboard brand.
https://www.asus.com/campaign/aura/us/SDK.html
https://linustechtips.com/topic/935009-fan-current/#findComment-11419022
But will both the fan and the motherboard’s rgb work? Cause I heard that if you have two different rgb controller , everything freaks out.
https://linustechtips.com/topic/935009-fan-current/#findComment-11419036
They are completely isolated, and use different software so it won't have any issues. The motherboard has it's RGB control built in and Corsair uses it's own lighting control module and Corsair Link. If there is a compatibility problem or conflict with the software itself for some reason that is a different story all together.
https://linustechtips.com/topic/935009-fan-current/#findComment-11419042
