Cable management tips?????
Go to solution Solved by w1nger1,
Go watch some video on youtube. Is kinda hard to explain in words. In short, use cable tie.
Or if you are lazy about it, you can shove it under the hdd.
I can’t seem to get my cables to fit behind my back panel. I’m working with the Corsair SPEC-ALPHA, anyone got any tips?
Here are my specs:
  • CPU: Intel - Core i7-8700K 6-Core Processor OC @ 5.0ghz
  • Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
  • Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard
  • Storage: Western Digital - WD Blue 1TB 2.5" 5400RPM Internal Hard Drive
    • Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive
    • WD 4TB Black - Passport
  • RAM: Corsair Vengence RGB 2x8 RAM
  • Graphics Card: MSI - GeForce GTX 1080 Ti 11GB Founders Edition Video Card
  • Case: Corsair Crystal 460x
  • Power Supply: Corsair - CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply
  • Operating System: Microsoft - Windows 10 Home OEM 64-bit
  • Monitor: Dell - S2417DG 23.8" 2560x1440 165Hz Monitor
  • Keyboard: Corsair K70 Mk II
  • Mouse: Corsair - SCIMITAR PRO RGB Wired Optical Mouse
  • Headphones: Bose QC 35 II - Active Noise Cancelling Headphones
https://linustechtips.com/topic/934699-cable-management-tips/
