Hi everyone,
I was bored and tried to get my ROG Front Base working which has never really worked since I got it when i bought my Maximus Vii Ranger. I found a post that said I need to install Asus Ai Suite 3 which I did but after the restart when I booted into Windows 10 my keyboard and mouse would not work... I wasn't able to boot into safe mode either. I have eventually got it working by turning Intel XHCI mode to disabled (default = Smart Auto). I have uninstalled Ai Suite and used the Cleaner, updated the chipset drivers but still no luck. the issue is that as xhci is disabled all my usb ports are running at 2.0 speed. I am typing this while I get a flash ready to try run a windows repair.... any ideas would be appreciated!
Thanks
BsK
https://linustechtips.com/topic/934624-help/
