If it just started to thermal throttle and you have not changed anything, you probably need to just clean it. Take it apart and blow all of the dust out of the cooler. Also, try some different thermal paste such as Arctic MX-4.
2 minutes ago, Jayjaysquid said:
Can you help me please
Also, be patient for a response. I noticed you posted this like, 1 minute after you original post. It takes time for people to collect advice and do research. Please be patient. :)
Please Quote or tag me @GigabitXe to make sure I see your reply.
https://linustechtips.com/topic/933464-build-help/#findComment-11403719
Yes, it's compatible. AM3 / AM3+ use the same mounts.
https://linustechtips.com/topic/933464-build-help/#findComment-11404861
