Hi!
I was cloning my laptop's drive to another drive and during the process, the recipient drive got disconnected due to my fault and I had to force close the process. Now, I cannot access the drive. Whenever I open disk management, it stops responding and I have to force close it. Same happens with windows explorer. I tried formatting using diskpart, but that didn't work and the 'chkdsk' command in Command promt also won't work for that particular drive.
During booting process, I can't  go into BIOS, unless I disconnect that drive.
Is there any way of fixing it or is there something wrong with the hard drive on a hardware level that can't be fixed?
PS- I made sure that the UEFI was in AHCI mode. I also tried disabling Legacy BIOS boot; but that didn't work either.
https://linustechtips.com/topic/931431-hard-drive-wont-work/
Can you go on to a Motherboard and flash it?
CPU i7-7700k 5.5GHz Delidded GPU MSI 1060 6GB ARMOR OCV1 +335/+1000 RAM 16GB 2x8 Corsair Vengeance WLED 2400/3000 C14 COOLER Corsair H100i v1 BOARD MSI Z270 SLI SSD Samsung 960 Evo 250G, x3 2T Samsung 860 Evo HDD WDB 4T, WDB 1T PSU EVGA 650GQ80+M CASE Cougar PanzerS
CPU i7-10700k GPU MSI RTX 2080 Duke POS RAM 32GB 2x16 Corsair Dominator Platinum RGB 3200/3600 CL14 COOLER CM MasterLiquid ML360R RGB Push/Pull BOARD MSI MEG Z490 Ace SSD 980 Pro 500G, 860 Evo 1T PSU EVGA 1000P2 CASE Phanteks Enthoo Luxe TG Black
CPU Pentium G4600 GPU MSI GTX 1080 Armor OCV1 +100/+400 RAM 8GB 2x4 G.SKILL Aegis 2133/3000 CL16 COOLER Corsair H100i v1 BOARD MSI H110M Pro-VD-Plus SSD 860 Evo 1T HDD WDB 500G, WDB 1T PSU EVGA 430W Bronze CASE Deepcool Tesseract/ VIVO
SERVERS i5-3470, i5-3470, i5-4590 GPUS MSI 750Ti 4GB, BFG GTS 250 1GB, GTX 690 RAMS 3x 16GB 2x8 1866 C8 PSUS 2x EVGA 1000T2 COOLERS Stock, Stock, Custom Loop BOARDS Intel, Intel, EVGA Classified SSD x3 860 250G HDDS I don't care to list CASES Optiplex, Optiplex, 2000s Water Case
560HP/607TQ E85 198MPH2000 Audi S4 2.7Bi-Turbo with K04/RS6 Inlets SRM -  DAZ Tune - 2.8L N/A DOHC Heads  -APB Block - Mahle Pistions - JHM Racing H-beam Rods - TheTuner Manifolds - 3.5in to 3in Exhaust with Magnaflow Dual Box - Dual Titanium Exhaust Tips - SAI CNC Delete - S4 Modified Airbox - 85MM Maf- RS4 Intake Manifold p&p RS4 Y-pipe - RS4 Bi-pipes - RS4 Fuel Rail - A8 TTB - Billet Divertervalves - Silicone Hose Everything - SRMv4 Intercoolers - Clutch Fan Delete/Block off - Power Steering Light Pully - FluidAmper - Billet Cam gears - V8 Cam Bolts - ABS Relocate - VW Diesel Oil Pump
https://linustechtips.com/topic/931431-hard-drive-wont-work/#findComment-11384831
5 minutes ago, Classified101 said:
Hi!
If you have other pc, try to connect it there. If it is not working, try using hirens boot cd. But first. Access your bios and configure already your boot settings. Disconnect other drivez except the keyboard, mous3, odd or usb( depend on where did you install your hirens) then try booting it.
https://linustechtips.com/topic/931431-hard-drive-wont-work/#findComment-11384842
1 minute ago, t4ils said:
Can you try booting GParted and formatting it from there? https://gparted.org/download.php
Burn ISO to USB, unplug the corrupted drive's SATA cable with the power cable still plugged in, boot off USB, and then plug the drive back in?
That worked for me on a 2008 Toshiba
https://linustechtips.com/topic/931431-hard-drive-wont-work/#findComment-11384855
I did connect to another PC, and the same thing happened there as well.
I also cleared CMOS but in vain. As I mentioned, I cannot access the BIOS only when that particular drive is connected otherwise I can access it and boot into windows without any problem. I made sure that it did not have the first boot priority, still.. nothing.
https://linustechtips.com/topic/931431-hard-drive-wont-work/#findComment-11384861
Okay. I'll try it.
https://linustechtips.com/topic/931431-hard-drive-wont-work/#findComment-11384865
1 minute ago, Classified101 said:
Okay. I'll try it.
Worst case. Make a video putting gasoline in it and throwing dumbells at it.
Edit: also burn it, and put grass on it.
Edited by Crazycatman
Additional information
https://linustechtips.com/topic/931431-hard-drive-wont-work/#findComment-11384870
2 minutes ago, MizuNano said:
As I mentioned before, with the drive connected, DISKPART won't work. It would just stop responding unless I force close it.
https://linustechtips.com/topic/931431-hard-drive-wont-work/#findComment-11384901
haha! Before that, I'll try claiming warranty cuz it is still under warranty and see what happens.;)
https://linustechtips.com/topic/931431-hard-drive-wont-work/#findComment-11384908
Hey! I tried using gparted and the same thing happened; after plugging in the drive and refreshing gparted, it would keep on refreshing. I kept it for about 30 mins, but nothing happened. But as soon as I disconnected the drive, all the other drives would appear. I think there is a problem with the drive itself.
I will now try contacting seagate and see what they say.
Thanks for the help btw!!
https://linustechtips.com/topic/931431-hard-drive-wont-work/#findComment-11385929
