I bought a h100i and my motherboard heatsinks were too close to the rad and fans so I ghetto mounted it above the mounting holes and that all worked out perfectly "Pics tommorow maybe" and what I was wondering was why the h100i's pump is so damn loud!
I installed corsair link too but from there you can only change the fan rpm and not the pump rpm does anyone know a fix for this or if this is normal and will go away with time? Thanks!
WTF, the second I posted this topic the whinning stopped and now it is super silent!
Luck I guess lol:D
post-43522-0-91511300-1388002604_thumb.j
https://linustechtips.com/topic/93134-h100i-pump-noise/
