That would have to be in the BIOS. Since it's a laptop it will look quite a bit different from normal BIOSs. Since it's crashing I think it's very much within warranty claims because the laptop is designed to be able to withstand that 3.5ghz mark yet it's not.
https://linustechtips.com/topic/930500-how-to-lock-cpu-speed/#findComment-11376253
yes im returning it but in the mean time i want to be able to run games for more than 0 seconds.
https://linustechtips.com/topic/930500-how-to-lock-cpu-speed/#findComment-11376254
7 minutes ago, VicciVicVic said:
Well if you change the BIOS settings then that voids your warranty so there isn't really much you can do about that.
In what universe does modifying your bios settings on a stock machine violate your warranty?
Bios is there to enable you to configure your device. It's no different than changing a setting in the settings app in Windows.
It's a much different situation than, say, someone installing a modified bios to access settings that aren't exposed by default, that would absolutely be grounds for voiding the warranty. Bot changing settings on the stock bios? Please.
https://linustechtips.com/topic/930500-how-to-lock-cpu-speed/#findComment-11376281
how do i change bios? i dont see any setting in it for this kind of thing i just see garbage like username and stuff
https://linustechtips.com/topic/930500-how-to-lock-cpu-speed/#findComment-11376284
When you start your machine up, before windows loads, you'll need to press a specific key combination. For most machines it's Delete or F2, but you'll need to check your manual to confirm exactly which key you need to press for your machine.
The setting you want to disable is intel turbo boost.
https://linustechtips.com/topic/930500-how-to-lock-cpu-speed/#findComment-11376290
Because it's a laptop and if you change frequency settings/turbo boost then that could very well void your warranty.
https://linustechtips.com/topic/930500-how-to-lock-cpu-speed/#findComment-11376305
Sorry, but no. Just no. Laptops without overclocking support have no options in their bios that could cause hardware damage. Laptops that do make you fully aware that it's at your own risk.
Disabling Turbo Boost is not in any universe, ever, going to void a warranty.
https://linustechtips.com/topic/930500-how-to-lock-cpu-speed/#findComment-11376327
i fixed it dont worry thanks for your guyss help tho
https://linustechtips.com/topic/930500-how-to-lock-cpu-speed/#findComment-11376416
